Astra 1, 2 and Hotbird on a zone 2 mini dish?
daro2096
No setup at present
Consett, Durham
Is it doable? 19.2e in the centre with 28.2 and 13 either side on a zone 2 mini dish? Will it work? Am in Consett.
satelliteman
Yep, easily done. You need a suitable offset bracket of course. There are several threads and images of similar setups in this section.
daro2096
No setup at present
Consett, Durham
Would the Inverto Multiconnect kit work?
satelliteman
Never used one. I have seen a modified Gibertini bracket do the job though. Sure a universal bracket will be up to the job in hand.
daro2096
No setup at present
Consett, Durham
But would it work?
You are better off using Sky lnb's - others wont illuminate the dish properly due to the oval shape of the dish.
Hope those invertos behave better than the similar shaped no name lnb Ive tried - mine are AWFUL in the rain!
daro2096
No setup at present
Consett, Durham
Would 9e be gettable in addition to 28.2, 19.2 and 13 on a zone 2 minidish?
Probably need 2 multi lnb brackets.
daro2096
No setup at present
Consett, Durham
Hello? Anyone? Would 5e and 1w work too or would it be beyond the capabilities of the dish?
daro2096
No setup at present
Consett, Durham
Using two of these brackets on a 60cm minidish?
sonnetpete
wordpress.com
Normandy, France
Don't think that you could get an arc from 28E to 1W on that dish. I go from 5W to 13E on a Penta 85 and that's just about at it's limits...
satelliteman
Raven Gemini 70 with E/W bracket would achieve that. These are perfect for LNb offset setup's, although not sure if the dish is still available now.
daro2096
No setup at present
Consett, Durham
I can't find one for sale anywhere.
sonnetpete
wordpress.com
Normandy, France
daro2096
No setup at present
Consett, Durham
That website has a copyright at the bottom of 2005. That is 9 years ago. Could be an out of date page.
Think I will stick to 28 to 9. Not much on 5e and 1w anyway.
Ghostleader
Glasgow,ish!
Daro I don't think much of the Inverto multi connect rail system, the LNB's are quite frankly........well sh#t really buddy.
daro2096
No setup at present
Consett, Durham
Would be using Sky lnbs. Can't afford those LNBs.
Ghostleader
Glasgow,ish!
The Inverto rail is only suited for their own LNBs mate, unless your "white trash" modding it mate?
Ghostleader
Glasgow,ish!
MK4 dishes has a most disagreeable new arm/LNB holder system as well, what age is yours mate?
Ghostleader
Glasgow,ish!
Here was mine from a while back: uploadfromtaptalk1412535768250.jpg
daro2096
No setup at present
Consett, Durham
Ghost leader.
There are 40mm bracket adapters for mk4 minidishes you know.
I would be using the multi lnb bracket like in the picture I uploaded in an earlier post on this thread not the Inverto bracket.
Haven't got any dish at the moment. Weighting up the options first. That and I am skint right now.
