thanks. still doesn't explain what is obsolete about it. Maybe a conditional access issue?
Nagra, Viaccess, Seca ==
== Nagra.
how are they obsolete if they can receive this message, and therefore DVB-S2?
Looking from a distance (Spain) and not knowing what they have now.
It's clear that the new 4K receiver with 8 tuners, most likely FBC, will offer a lot of flexibility up to DVB-S2X (I hope, since we also have the first versions of DVB-S2 with 8 tuners), and being 4K, it supports HEVC and then HD in H265.
In addition to having an IPTV connection for more options.
The FBC tuners represent an increase of €80; I don't know the actual factory price, but it's the cheapest solution for having 8 tuners.
Offering a lot of flexibility in community installations (upgraded to unicable), as well as in individual installations, with a single cable, you can tune 8 channels/frequencies of any band and polarity.
The old receivers are DVB-S2 and H264; by changing the receiver, the advantages and savings on the satellite are very significant.
They can achieve a 51% transmission savings for similar apparent quality.
If it supports PCMCIA and also has standard readers, they already have a great future ahead.
Time will tell.
Mirando desde la distancia (España) y sin conocer lo que tienen ahora.
Esta claro que el nuevo receptor 4K con 8 tuner, lo mas seguro son FBC, darán mucho juego hasta DVB-S2X (espero, ya que también tenemos DVB-S2 de las primeras versiones con 8 tuner) y al ser 4K, admite HEVC y luego HD en H265.
Aparte de tener conexión IPTV para mas opciones.
Los tuner FBC suponen un incremento de 80€, en fabrica no se el precio real, pero es la solución mas barata para tener 8 sintonizadores.
Dando mucho juego en instalaciones comunitarias (actualizadas a unicable), como en instalaciones individuales, con un solo cable, se puede sintonizar 8 tp/frecuencias de cualquier banda y polaridad.
Los receptores viejos son DVB-S2 y H264, con el cambio de receptor las ventajas y ahorro en el satelite, son muy importantes.
Pueden llegar al 51% en el ahorro de transmisión para tener una calidad aparente similar.
Si admite PCMCIA y también tiene lectores normales ya tienen mucho futuro ganado.
El tiempo dirá.
