Astra 1N at 19.2E
11836,light rain now western Greece 14dB
St. Petersburg new TP's Astra 1N:
11494 H - 0% (before 96%)
11582 H - 0% (before 95%)
11836 H - 1% stable picture (before 96%)
11954 H - 0% (before 93%)
12633 H - 0% (before 95%)
12663 H - 0% (before 96%)
12692 H - 0% (before 97%)
Seems you're off the edge, but looking at the 1N map, maybe a (very) large dish can do the job ?
By evening, the situation has improved slightly (11494H):
General 20-30% lower signal strength on the channels that moved = OK below 12604 but loss of weather margin. 12604 & above very weak.
So will need more than 60cm here. Seems to match the 1N reception map, steep rolloff above western Norway. Probably, the 90cm (currently 28.2) will go to 19.2, when I get the larger dish for the needs of 28.2 UK beams.
tp 69 11798h move to astra 1m wide
tp 81 12032h move to astra 1n
tp 82 12051v move to astra 1n
Good morning, also moved:
Tp 73 11876 H move to astra 1N ?
Tp 75 11914 H move to astra 1N ?
Tp 83 12070 H move to astra 1N ?
Tp 87 12147 H move to astra 1N ?
Here are my signal changes today, some are a bit too close to call from here:
69 - 11.798H - Now 11.9dB on 1M Wide - (Was 12.7dB on 2C)
73 - 11.876H - Now 9.5dB on 1N PE - (Was 12.5dB on 2C)
75 - 11.914H - Now 9.3dB on 1N PE - (Was 14.8dB on 2C)
81 - 12.032H - Now 11.8dB on 1N PE? - (Was 12.3dB on 2C) Is this really 1N?? Strongest signal so far if it is. Looks more like 1M Wide to me from here.
82 - 12.051V - Now 10.6dB on 1N PE - (Was 12.8dB on 2C)
83 - 12.070H - Now 8.6dB on 1N PE - (Was 13.7dB on 2C)
87 - 12.148H - Now 8.3dB on 1N PE - (Was 12.9dB on 2C)
95 - 12.304H - Now 8.3dB on 1N PE - (Was 12.3dB on 1M Europe)
99 - 12.382H - Now 8.2dB on 1N PE - (Was 12.1dB on 1M Europe)
Could this one have moved to some other satellite last night too? 1L/1M Maybe?
85 - 12.109H - Now 12.2dB (Was 12.6dB on 2C)
the tp 95 na tp 99 i see same signal like before
Moved to 1N:
http://www.flysat.com/astra1n.php
Very strong sygnal here
Sorry popovp, but links to Flysat and other web site listings are no proof of anything at the moment. These transponders switched a few hours ago and these Flysat/KoS/Lyngsat/etc details are from members of this and other satellite forums. Even SES's own sites are incorrect at the moment. You might as well post a link to this thread...
Changes, changes... (well, I have to admit that I like those ones! )
Before (8 of March) on top, now bottom... :)
Here are my signal levels as of this morning.
A lot of thanks for your daily updates! It's very useful for me.
IMHO 12032H is on 1L , because 1M is a little bit stronger. And I'm absolutely sure, that it's not on 1N. I see 0dB on all transponders of 1N to my great regret! :(
Thanks, and yes 1N is a real pain, sorry to hear your 0dB reports, at least it's not as bad for me as I feared...
Can you see 12051V in Moscow?
Edit: I don't think 12032H can be on 1L as I don't think 1L can broadcast on that frequency. Still think it's 1M Wide.
@timo w2s
i check sky news hd 12304h it gone at evening
it also also 12382 h also gone signal
it move to 1n also ?
please chek tp 27 11612h it move 1kr to 1m wide
\what time are you check it tp of 1n ?
