Astrovox VSR-2600 FTA No firmware!!!!!!!!!!!!!!!!!
fr92fab
There is no solution on VSR-2600 FTA ....No firmware from astrovox.biz
Astrovox 2600 FTA=Pansat 2300= lifetime but impossible to have clear informations....
Thank you Astrovox for your supportO-no
Best regards for somebody have solution.
Fabrice
IjonT
Opentel 3500 FL, LNB 0.6 dB, 60 cm Fe
I have found this on astrovox.biz: _http://www.astrovox.biz/Data/DownloadData/VSR-2600%20FTA%20G.zip
fr92fab
Thanks, but this one is older than 1 year , I think astrovox stop to upgrade the soft.
But Astrovox srv-2600 FTA = Pansat 2300 = lifetime
May be it is possible to find easier these files and also the procedure!!!!
If you have some idee
Best regards
Fabrice
IjonT
You can find Pansat downloads here:_ http://www.pansatusa.com/download.htm
skull
satellite freak
www.rdi-sat.com
4x100 cm televe's dishes,with echostar quad lnb's, INNOVATIVE I.P, humax, echolink fta and kaon receivers. super jack h2h motor.
Persian gulf
I HAVE THE FILES NEEDED TO CONVERT VSR-2600 FTA INTO FORTEC STAR LIFETIME . AND NOW IAM GETTING THE LATEST PATCHES . AND AFTER FIVE HOUR I WILL UPLOAD THEM FOR U.THANKS
skull
satellite freak
www.rdi-sat.com
Persian gulf
1. FIRST OPEN LOADER, THEN IN STB MODEL WRITE key:global
2. then in the bin file load delete. bin file and start downloading
3. then in the stb model write fta and in the bin file load the boot.bin file boot_fta_60_......and check the boot file in the file type and start downloading
4. now in the stb model write Al7bar FTA and in the bin file load file Al7bar FTA-0916-218 api and start downloading after that cheers your 2600 have converted into lifetime.
5 now in the stb model write fta and in the bin file load boot.bin file Al7bar FTA_FTA ver 60_040515 and in the file type check boot file and start download.
6. now in the stb model write Al7bar FTA and in the bin file load the latest bin file i.e Al7bar fta _050227_256_api and start downloading now ur receiver is patched with the latest software dated 28.2.2005.
SINCE I DONOT KNOW HOW TO UPLOAD FILES SO U PGUYS HELP ME HOW TO THEN I WILL UPLOAD THEM AS I PROMISED.
skull
satellite freak
www.rdi-sat.com
Persian gulf
SO TELL ME...............
Your instructions will be helpful to someone I'm sure, but don't even think of uploading any files to this forum (read the rules).
Just point to a site that they can be downloaded from.
fr92fab
Ok for the firmware I will find it. For loader what is the version to use?
I did not find the file delete.bin ?
Thank to give me the link or send me to my email the files.
Fabrice
skull
satellite freak
www.rdi-sat.com
Persian gulf
THANKS LIEW, THIS HAPPENED BECAUSE I HAD NOT READ THE RULES, THNX AGAIN MAN NOW CHEER UP!!!!!!!
fr92fab
I tray with last al7bar fta ...257 but tps is not working !!!! Why??
Best regards
shasse
:) je trouve mieux de le changer a alpha star son changer le remote
ghaoui
i need any information about astrovox
how can i transform my receiver astrovox 2600 fta to alfastar
ghaoui
help me to convert my receiver astrovox 2600 fta
please!!
kaleem3399
i m new to it...
pakistan
Hi i need the delete.bin file for astrovox 2600 to convert it in to fortecstar ... plz friend send me the delete file to kaleempersonal@yahoo.com
thanks in advance
staruser
Albania
Please send me also delete.bin file in Humihobi@yahoo.com
gervais
i am networking administrator and telecommunication technician
cameroon
good morning
can somebody give the diagram connection cable to make connection between P C and astrovox
i use serial cable null modem but it was impossible to communicate
thank for reply
best regard
