s-band
- Feb 7, 2016
- Essex
I did it to play with some old Dexcel LNAs and to improve the stability of the wide band modified Tit. The down-converter chip is on the verge of instability unless it has very good in/out isolation or a well matched input filter (which I removed for the wide band modified tit). The plan was to use a dual probe front end (e.g. Zinwell), take its output to a wider band filter to cover 3.6-4.8G and use this BDC. By separating the stages in different boxes, the chance of instability is reduced a bit. It may work over the whole range without switching the LO if used with the TBS6983.
Assuming the device at the base of the Y in the Zinwell is an amplifier, that's where I'd take the LNA output. However, I doubt it will be tuned well enough to cover the whole band. So, in blocks:
LNA > Filter > Attenuator? > Down-Converter It'll be low on the priority list though.
