New Channel B1 TV HD
astra19
98cm motorised technomate. 50e to 34.5w
Europe
Romanian news channel on 12252V. Not easily receivable FTA up here, so it’s a nice change. Normally I access it via streaming.
Also on the transponder is Romanian sports channel Pro X, encrypted in Viaccess. I’m curious as to why it’s there because none of the providers use Viaccess.
cybertomanek
Laminas AS-1500 +Jaeger SMR 1224 80E - 45W
U2C Denys H.265
Poland
12252 V 30000
I'm sure my report at 39.0E won't help you- because we receive the satellite at large distances from each other. But in my area, which the provider is targeting, Telecom TV, the signal is very good even with a small antenna. However, it should be known that the strong signal on the satellite is not equal on all transponders of the same TV package even if it is on the same beam. This is why the signal reserve from the same operator on each transponder is not the same. In such cases, it is advisable to install a larger antenna when there are signal drops, especially in bad weather.
Probably, as this minimux has been recently launched, it is possible that the problem is precisely the encryption system, Viaccess, maybe, who knows, in the experimentation phase, although it should not be a reception problem.
If the receiver is from the operator, it is advisable to update the software in case new parameters appear.
If you think it matters for a reception at 39.0E in your area, here's what the signal looks like in my area and although I don't see how that helps :)
Satspot
Technomate TM5402 M4
1.2m Triax dish
Technomate H to H motor
Ireland
b1 HD and Pro X HD showing on 12252 V 30000 and 12246 V 30000 in Dublin. Signal quality 90%
astra19
Europe
39E has a strong signal here, but the other location that carries B1 TV, 31.5E is a lot more difficult for this area.
There has been some rumours over the years that Freesat Romania might move because its current location, 16E requires a much bigger dish than 39E for example. Pro X is part of that package, though only in SD at the moment, and B1 isn't, so it's possible this is something different entirely.
