Badr or Nilesat
RichardinSpain
Totana, Murcia
Dreambox 500s motsat3 motor
Totana Murcia Spain
Hi all, hope i'm posting this question in the right place
Can anyone tell me which has the most english speaking tv channels (free to air) Badr or Nilesat
cheers
Richard
satelliteman
Have you browsed through the satellite lists?
_http://en.kingofsat.net/pos-26.0E.php
_http://en.kingofsat.net/pos-7.0W.php
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
Roughly about the same comparing badr4 to 101/102 Nilesat verticals, with Nilesat getting Fox series, badr4 not. As for badr6 Nilesat H ??
Best way for you to find out, is try out both positions with your dish, and see what you can pick up from each. Also, bear in mind the effect of the coming into full service of Nilesat 201 may have. The main channels you'll be looking for are the MBCs (MBC2,MBC3, MBC4,MBC Action, MBC Max,MBC persia), Fox series ,Fox movies and Dubai One.
jpsr
1.2 channel master, cm polar mount, 12 inch actuator, Andrews feedhorn, Inverto lnb, Superjack positioner, Dreambox dm 500s, Protek 9600ip, 1m channel master with black ultra & 1m gibertini with technomate twin output lnb on astra 1/2, TM 5200 & 1000
Mullingar, Ireland
I get all the mbc's at 78% quality, in all on 26e i get over 300 channels on a 1m dish.
When i had an 88cm i could not get a single channel.
