BBC DVB-T England package Eutelsat W7 36° East
ta6ish
Skystar USB HD, Eurobird 9A, 1.86 Core 2 Duo
Pakistan
BBC DVB-T Package started on EutelSAT W7 after EutelSAT W2 anomaly.
_http://www.flysat.com/eutelsat36.php FlySat Eutelsat W4/W7 @ 36° East
I tuned it and signal is fully locked on DVB-S PCI card but when i scanned it got nothing ... blank frequencies. I m confused why im not getting channels even when i m getting good signal please help in this regard.
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Hello
Welcome to the forum ta6ish
You cannot watch it because it is encrypted in Mediaguard2 and it is not meant for satellite viewing as it is a terrestrial feed hence DVB-T not S
You wont be able to tune it with any hobby gear - I could lock the old W2 signals easily enough but nothing scanned.
The signals are manipulated so that only professional broadcast equipment can receive it. Therefore if you are hoping to watch UK tv in Pakistan (which is where your IP address resolves to) - forget it.
ralphmagno
naples italy
hello,
were is this frequency
i went to lyng sat and did not find this
ralph
ta6ish
Pakistan
did you mean the only BBC's own set top box can receive it ? and by the way Pakistani proxy servers runs fast ;)
11051h 17578 5/6
11076h 17578 5/6
Yes. Please fill your location in correctly - we cant answer techhnical questions if we are making incorrect assumptions about your location.
Thye nearest big town in the UK your country elsewhere is close enough.
ta6ish
Pakistan
Thanks i did it. So is it possible to manipulate DVB-S modulation also or it only applies on DVB-T. Sorry for bad english
ta6ish
Pakistan
Sorry for re-post got no edit option but one more thing so it means that a DVB-S tuner can tune-in a DVB-T Frequency?
ralphmagno
naples italy
hello
a satellite tuner can not tune terestial freq.
satellite run from 950 mhz to 2150 mhz and use qpsk modulation
terestial uses depending on zone in europe 170 mhz to 230 mhz and 470 to 890 mhz and may use q-am modulation.
unless you have a box that is terestial and satellite both but it will not be a sky box for sure
ralph
