BBC & ITV streams on F3/5 & TM 5402 M3
Distant expats - Ive just loaded the latest iptv stream list for the 5402M3 & Ive found the BBC & ITV streams are currently working.
Enjoy whilst they last!
Edit - M3 added to post
skomedal
This and that
thule
Think the patch is for the M3 model, not sure if you can use it with the M1 and M2 versions.
Regards
Its just the stream list - I would have though it would load on all the models? Its not listed as M3 specific unlike the software downloads.
skomedal
This and that
thule
Sorry cannot find the IPTV option in the 5402 M2 menu, where is it in the M3 menu. Can find it in my spiderbox 6000HD menu no probs.
Regards
Regards
That is because it is not there only M3 & F_3/5 support IPTV.
skomedal
This and that
thule
So post 2 was correct not tm 5402 universal.
Maybe AS could make this clearer in the thread title.
Regards
Sorry lads - not had a chance to play with anything earlier than an M3& hadnt realised they dont have the function - I'll change the title.
Kveys
Southern Finland
AS you forgot F-3/5 :p ( well, maybe I am only whos using that stb anyway ). In fact it is good reciever with sat and iptv both.
skomedal
This and that
thule
Well done AS
Pity admin on similar sites are always right and if you comment their posts you get either suspended for a period of time ( no appeal ) or forbidden to enter that forum for life.
Regards
I always hold my hands up & say "ok sorry folks Ive goofed" when Im in the wrong . People respect you for it. :)
And if you are transparent in your dealings on the forum folks stick around.
