BBC One HD & BBC HD Problem
Irishmale
Fuba 85 dish, fuba LNB, Kathrein UFS 910(BPanther Neutrino), DM800(Nabilo v12), Share....
NRW, Germany
Hey guys,
hope i am in the right section....:confused
So to my problem, since the transponder change i cant get both channels on my Kathi UFS910 with the AAF MME Image. I have tried a full sat scan, a manual transponder scan, a single cable from lnb to reciever.....
I am using the following:
Tunen-----Manuellar Transponder
Sat-------Astra2...
System------DVB-S2
Freq--------10847
Inversion--------Auto
Symbolrate------23000
Polarität---------V
FEC-------------8/9
Modulation------QPSK
Rolloff----------0.35
Pilot-------------Auto
It cannot have anything to do with the sat, lnb or diseq as my Dreambox is running perfectly on the same system.
Maybe the tuner is not good enough. On the Dreambox how close to the receive limit are you?
Irishmale
NRW, Germany
I have a signal strenght of about 65% on both receivers.....if this is what you mean.
ralphmagno
naples italy
hello,
try 10.850
i had a lnb move 3 mhz and it would not lock.
add 3 mhz or subreact 3 mhz and see if this works
ralph
Irishmale
NRW, Germany
Hey Ralph thanks for the tip but it doesnt seem to have helped. I have tried 10 +/-
Think my Kathi will have to take flying lessons as it is soon going to fly out the f++king window
roaduser
Mvision HD-270CN Sly oval and 80cm through Diseqc for astra 28.2 and 19.2. Technomate 6900 combo and Metronic for other rooms. Optical Audio for 5.1 through Technics receiver.
Lincolnshire
they have vanished off my technomate too :confused
Have you rescanned using the correct parameters??
DVB-S2
SR - 23000
FEC 8/9
You may need to delete the old BBC HD channels first.
And select 'network' within the search parameters.
Irishmale
NRW, Germany
Hi guys,
For AAF USB images...
replace your cx24116.ko to be found Lib/modules with the one below & do a new scan of the transponder........
