best place to get a dreamcooler & a quick question
ireilly24
DM800HD
FULL SKY UK HD
leicester
where is the best and cheapest place to get a dreamcooler from.
also my fan in my 800 clone is noisy can i disconnect this when i have a dreamcooler or replace the fam easily?
Eek!
DM800
Just seen it myself on e.bay. They look interesting but pricey at £25 + £9 p&p. If you find anything better/cheaper let us know!
shumifan50
2xDM7025(DVB-S tuner), DM600SPVR, DM800S, DM500S HD, Triax 90cm with MultiBracket 4 sats.
Europe
Look on fleabay. I posted a link on this forum a while back.
indublin
Lidl ali sat box with a basic dish. Frontier dish with multiple lnbs. Not setup yet DM7020s waiting for it to arrive
Ireland
I have two on the way from Ebay..
-http://cgi.ebay.co.uk/Dreambox-cooling-fan-cooler-base-dm800-HD-Kuhler-Pad-/170479451905
[fieldset=Admin]no live links please as per the rules[/fieldset]
paxrax
☆☆☆vu+ duo☆☆☆
dm800s (rev m)☆☆☆
dm800s (rev l3)☆☆☆
1m motorised dish☆☆☆
zone 1 sky dish☆☆☆
uk
there are a few ways to cool a dm800,
just search ebay for netbook cooler or
cut the adapter off an old mobile phone charger and connect it to a 12v pc fan and pop it on top or
cut the end off an old usb cable and connect it to a 5v pc fan and either insert inside or drop on top (theres a usb port under the hdd caddy)
alternatively, if the fan is noisy, remove it, remove the sticker from the centre of the fan an put one drop of 3 in 1 oil on it, works a treat!
redone
dm 800hd...
Zone 2 sky dish motorised..
Moteck 2100.. Dbox2 upstairs
uk
Or just remove the fan......
Got two clones here..Fans removed running sweeeet..
Obviously don't mount on top of your ferguson videstar
walter_red
Single dish, DM800 HD PVR, PC; (xp), Laptop; Vaio (vista)
Took the wires off my fan because of the noise but the top does get really hot - will it be ok? The genuine DB's don't even have a heatsink according to a 'spot the clone' website I looked at.
aamir007
PC: Intel Quad Core 2.55 ghz 4gb ram Nvdia Gforce 7900
PS3
Dream Box 500\518\800
West Yorkshire, UK
A bit ridiculous the size of the fan in the clones its too small as soon as i saw it i removed it and placed a usb fan cools much better
