best setting for sony bravia
fanthom
1m dish, spiderbox hd9000, sony pc
manchester
I just purchased SONY BRAVIA KDL42W653 LED SMART TV and I cant tune up the picture, I tried so many different setting but I still cant get nice color sharp picture, the tv is connect with av cable to sky hd box. Anyone have same tv and candidly can give me full picture setting? THANKS
AV Cable?
You need an HDMI Cable for decent results.
fanthom
manchester
yes I know but I dont have the hd packed and the best way to view the channels is through av cable. I did try and seem the color of the picture goes more yellow but dont with av cable
HDMI Cable connection will allow Upscaling .......................
fanthom
manchester
S
Steve Steve
Sky SD sometimes looks a bit soft and fuzzy via HDMI.....I found for the best SD picture..(with a Sky HD box)....use a good quality scart cable set to RGB output........
This way allows the TV to do the upscaling ...not the crappy Sky hd box.......
fanthom
manchester
yes I did that but still have the same problem the picture is yellowish in av or hdmi cable, what could be the problem?
sonnetpete
wordpress.com
Normandy, France
The Sony Bravia has extensive mode settings and colour adjustments to help you achieve exactly the type of picture you want. Have you tried adjusting these?
