If this is tj's excellent multiprog v0.07 you can resize by dragging the bottom right hand corner to make the window the best size for you and then closing the prog with the x in top right box. On reopening window should be the new size - well, it worked for me!
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
