Turok
- Apr 25, 2005
- Age
- 36
1,25 Fibostop
Jäger Smr 1224 & Smo 36 Dual Axsis Motor
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Tagra 2,20 M Fullsize Dish
Echostar 2,40m Mesh for cband!
- Austria
Hello!
after my echostar dvr 7000 burned up,got now a nearly new on from ebay!
now i want to rplace the small 40 gb hd,but when i put a 250gb in
that is i think the maxiimum sizre that can be recogneized
nothing happens,i look in my weblinks archive and found only this short text,how to asign a bigger hd
did someone one ever do this?
i use this receiver still efvery day to move the smr 1224!
here the little how too,is this realy all?
Hard disk change dvr 7000
After you have changed the hard drive, you have your first box with the new "make known". With HyperTerminal.
Clasp to your PVR via the serial interface at 9600 baud or 115 200 to a PC with Hyper Terminal, and type one or Initfactory Free,
then remove the power cord and plug it back again and enable PVR type. Then in the menu of a PVR Factory Reset do
also i want to install ,a quite temperature controlled cooler,and good bless a swtich on the backside,for the noisy hd,
need now component list,what cooler i should use !
thanks to all that stil use this realy old receiver from the middle age
