Blaze DTV - Eurobird/Astra 2 separated?
martyp78
USB DVB-S, Sky dish
West Midlands
Hi all,
I used to have both the above together in Blaze DTV but when I got a new laptop and reinstalled it it's now separate so that I either have a list of channels on one or the other as they wipe the channel list when scanning.
Does anyone know how to get the two together again?
Many thanks
martyp78
USB DVB-S, Sky dish
West Midlands
Hi all,
I've looked more into this and in both Program Files and All Users\Application Data folders for the BlazeVideo app there is a folder called 'Satellites' containing lots of ini files sourced from the following location:
_http://joshyfun.cjb.net
I noticed that in the satellites folder there is a 282.ini (Astra 2A etc) and a 285.ini (Eurobird 1). On that website though there is only a 282.ini file, not one for Eurobird. There seem to be many more in that latest ini file on the website so is it likely that the Eurobird ones have been incorporated?
I did a full scan on 282 (Astra satellites) and got just over 700 channels?
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
In general terms they are classed as co-located so there should only be one ini file. As there is only 0.3 degree separation your dish will be unable to differentiate between them and they should both be pulled in at the same time
