Blue titanium + Infinity phoenix
dasteelman
85cm transparent dish
85cm Penta Dish (motored)
Black Ultra LNB
VU+Solo
VU+Duo
technomate 9100 linux
Quali-TV (4:2:2)
Eaglebox
UK nds card
Tyne and Wear
I am about to attempt programming my blue titanium card with the infinity programmer.
Can someone confirm that this is what I need to do:-
1) Download "titanium progger" software
2) Download "se*a 2 s*y It*lia" files.
3) Open the infinity software in "phoenix mode".
4) Open "titanium progger" software.
5) Put the card into the programmer
6) Download the "sec* 2 files" onto my card
7) Put into the satellite humax 5100 reciever.
8) Switch to FTA channel, turn off reciever, then back on
9) switch to a s*y channel.....
is that it?
You've missed out step 5)a, erase card, very important, otherwise all OK. :)
dasteelman
Black Ultra LNB
VU+Solo
VU+Duo
Quali-TV (4:2:2)
Eaglebox
UK nds card
Tyne and Wear
dasteelman
Black Ultra LNB
VU+Solo
VU+Duo
Quali-TV (4:2:2)
Eaglebox
UK nds card
Tyne and Wear
I hear people talking about having the correct O.S. on the blue tit card.
What does this mean, and how do I get the correct os on my card?
ps....my card hasnt been programmed yet (apparantly its blank)
If it is a recently delivered card, it may have either 1.03 or 1.06, both will probably be OK, but if it has the earlier version, you will be asked if you want to upgrade by the latest Titanium Progger version.
dasteelman
Black Ultra LNB
VU+Solo
VU+Duo
Quali-TV (4:2:2)
Eaglebox
UK nds card
Tyne and Wear
what happens why s*y it*lia change there codes? Would I have to reprogramme my card? or would i be able to update via remote control?
