s-band
- Feb 7, 2016
- Essex
I carried out some tests to compare a Bullseye LNBF with a SMW Q-PLL Type C on a 1.8m PF dish.
SMW Q-PLL Type C on IRTE C120 adapter
Bullseye LNBF with feed removed fitted to C120 flange from Invacon LNB
The plots here used Crazyscan's blind scan 1 with 2MHz steps. This gives more repeatable results than BS2 but doesn't catch all signals. I would normally compare systems using Sun noise but the tracking dish is out of use at the moment. Notes:
- Cloud cover changes resulted in 0.5dB variations, maybe more.
- 7E chosen as it was of interest at the time
- 10804 and 10845H give random values sometimes
- Skew set by nulling beacons. SMW had >32dB X polar rejection and Bullseye <27dB
- 10720H varied by the most with varying cloud (to be expected)
- Number of feeds varied through day
- Might be better to do 7W as that has most low level signals
- High SNR signals give poor indication of differences as 1dB RF change results in <<1dB SNR change when > about 15dB SNR.
- BS1 used with 2 MHz steps, BS1 & BS2 scans saved as .ini
