Buying new system please advice me
wiseguy4u
Can anybody advice me
Between these motherboards
Intel D101GGCl
Intel D102GGCl2
Intel 915 GEVL
and these processors
P4 3.06 Ghz ( 1mb cache - 533 Bus)
and
P4 2.66 D Ghz (533Mhz - 2 x 1mb cache )
Is this system will be 64 Bit compatible for Windows Vista?
Have Hyper Threading (HT) technology?
What is the graphic card memory of built-in ATI chip with 512 RAM?
Will I be able to record or atleast watch HDTV transmission by DVB card?
Any advice will be appreciated about compatibility issues such
as gaming.
2cvbloke
Near Pontop Pike, Co. Durham
Intel D101GGCl
Intel D102GGCl2
Intel 915 GEVL
and
Those are not 64Bit components, so, no...
Depends on the CPU, but it looks like another No...
Depends on the Bios setting, could be 8mb to 256MB, it's an option you can alter on most motherboards...
Maybe, but it would struggle as the CPU spec seems to be a bit low for HDTV compatibility...
as gaming.
What sort of issues? What will the system be doing primarily?
I build systems for a living so I can advise pretty well, and whatever you do, do not buy from Dell, they rip you off big time when it comes to repairs (and yes I did say WHEN, they break down faster than I can eat a pair of Greggs' sausage rolls!!!)...
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
I have not much idea about anything else but Vista in Beta and Candidate 1 (the latest release) is supplied in 32 and 64 bit versions I have both.
Hyper threading is required for efficient multi-tasking
I do not understand the question re graphics chip if the PC has 512 mb RAM then you need to know what proportion of that is allocated to the graphics chip, I would have said you would need 1Gb Ram on any modern PC these days or 512 if you are having a separate graphics card with it own built in Ram.
wiseguy4u
Thanks for everyone's reply
Are Pentium D processors not 64 bit ? and only CORE 2 processors
64 bit.
Is there any motherboard that supports both pentium D and CORE 2 DUO?
Intel has been promoting HT from many years so why Pentium D
is not compatible and which processors are compatible?
I have an 9250 ATI card on which I play Call of duty 2 will I be able
to play by on board graphics? as this AGP card will not work on
new motherboard because of PCX?
mhku
TM Nano ~ sg2100
Midlands
A 9250 is a low end card so why not upgrade to a better graphics card as well?
jimbo
Retired Mod
Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
Greater London
An Intel D Processor 820 with HT technology is a 64bit CPU.
I don't know why you need a m/b to support D processors and Core 2 Duo.
In recent processors the 'D' is the slowest, being outperformed by the Athlon AM2 which now supports DDR2 memory for the first time.
The Core 2 Duo is the fastest processor at the moment.
2cvbloke
If you're after a high-end system which is suitable for games, HDTV and high-end applications I'd suggest the following spec system (taken from my work's website):
AMD Athlon 64 Bit X2 Dual Core sktAM2 1Mb 4200+ Cpu,
ASUS M2N-E (PCI-X) with Raid,
1Gb (2x512Mb) DDR2 667 Ram,
300Gb SATA2 7200 16Mb HDD,
3.5" FDD,
512MB DDR2 Geforce 7600GS PCI-X,
16x DVD / 48x Cd Rom,
16x +/- DVD Re-Writer DL
If you want I can give you the price and contact details if you're in the UK and you can take it from there but it'll have to be by PM cos I'd get told off otherwise... :D
jimbo
Retired Mod
Greater London
AMD Athlon™ 64 X2 4200+ AM2 Processor
with HyperTransport™ Technology
ASUS PCIe Mainboard - nForce 430 Chipset
1024MB DDR2 533MHz Memory
320GB Serial ATA Hard Drive
512MB nVIDIA Geforce 7300GS Graphics
Sony 18x Super Format DVD Writer
16x DVD Rom Drive
5.1 Channel Surround Sound Audio
8 USB, 2x Firewire, GB LAN
Classic Warranty-3 Years parts & lab.
This system on the Mesh website is £438 inc VAT.
It's a pretty quick system for what seems a low price ... especially as a 3-year warranty is included in the price.
wiseguy4u
I previously had tried AMD but it has a problem working in extreme cilmates thats
why because of my location I will stick to Intel which has precission cooling technology
I have found these boards that will support these processors Pentium D, HT and CORE 2 DUO and are also cheap
D945GCLL
D946GZISL
2cvbloke
AMD's cooling has come a long way since the K6 and K7 type CPUs and the motherboards usually com with something called "Cool & Quiet" which ajusts the CPU fan speed to run the CPU at it's optimum temperature, so no more fried chips or jet engine heatsinks are needed...
jimbo
Retired Mod
Greater London
I think this thread is going round and round or up a blind alley.
Maybe I should stick it in the footy forum as the goalposts keep moving. :D
member91040
DISH TV,DIRECT DD+,
TATA SKY,HATHWAY,
NOKIA 9660S,
PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S
INDIA
Goo For , Intel D102GGCl2
Pentium D (Dual Core) 3.44 800FSB 2MB Cache ,Can be overclock,
Board support Shar 256mb Video, Pci Express & Pci 2.0 32bit
EM64 Enable, Low Cost, Ram Depends up on you. Chepest one,
Going for more high end ask me in next thread. Core 2 Duo in on.
2cvbloke
Errrm, this thread's a month and a half old...:rolleyes:
