C Band lnb Stargold sg-500k
antrabe
dreambox7080 dm900 viark droi
spain
Hello there is any manual to set up a multipunto lnb C band i dont know how to configure the tuner to be able scan H/V.
I would like to knows how set up on dreamboxes enigma2 the lnb stargold sg-500K. is a multipoint lnb with low and high 5150 mhz y 5750 mhz.
You need to set the LNB settings on the receiver to OCS or 5150/5750 local oscillator.
One polarisation (H or V) uses the 5150MHz LO, the other uses 5750MHz.
antrabe
spain
like this doesnt works and umbral?
Sorry I don't have an Enigma 2 receiver so can't be specific. What are the options for 'Tipo'? A search seems to suggest OCS/multipoint are not properly supported - but this was a few years ago.
