C band newbie
blackers
Gibertini 1.25, stab hh120,, vu+solo, tm5402hd, amiko micro hd, sky + hd full sub inc setanta..
Essex Uk
Hi all,
Fancy having a go at seeing what this c-band thing is all about.
Currently I have a gibby 1.25 on a stab motor, first question am I able to mount the c-band lnb next to my ku lnb?
Cheers
Sent from my GT-I9505 using Tapatalk
Archive-8
Hi all,
Cheers
blackers
Essex Uk
Thanks, this might be the first stupid question of many - does it track the arc ok like that?
Archive-8
Yes tracking fine :D I track 49e to 55W (only in the winter, due to a tree in the way) on the C-band. The other lnb's are ka/ku band.
blackers
Essex Uk
So I could keep my ku in the middle and put a c-band version to the left or right?
Archive-8
A lot of people have 2 cband lnb's 1 to the left of your ku, and 1 to the right.
That way you can have HV on 1 lnb and LR on the other lnb.
As you have to use a dielectric plate, for LR.
blackers
Essex Uk
Ooohh I will have a play. Any recommendations for one? Also I'm guessing any bracket arrangement would be a custom job as they are not 40mm wide?
Archive-8
You can get them very easily on eBay. What are you asking for recommendation for? Lnb, bracket.
blackers
Essex Uk
Lnb really mate, guessing I'll have to make a rail up to mount them on.
