C-band on 125cm Dish.
fif
Dreambox 5620,
Dreambox 600,
Openbox 810,
36v Actuator, Vbox-II
T90 8°W<>28°E,
Dish 180cm for C Band
Panorama LNBF+Waveguide
Germany/Holland
Hi all.
I´d like to direct the dish in 5°west AB to watch some africans channels. what should the c-band´s size holder be? How to fix the dilekterium(stick inside the c-band)?Did someone experience about it? With my 80cm dish, i can only watch European programs on 5° west.
Txz.
Turok
1,25 Fibostop
Jäger Smr 1224 & Smo 36 Dual Axsis Motor
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Tagra 2,20 M Fullsize Dish
Echostar 2,40m Mesh for cband!
Austria
Hello!
5 West Telecom Satelite ,is very strong in cband!
so your 1,20 cm dish would be okay!
inside the cband lnb,you see some notches,for the dialektrikum plate,there are to posible postions,on most lnbs,where you can insert it!
make sure,that is right closed,if it not cloesed 100% corectly,water comes in,and your lnb will be fault!
There are half a dozen Aftrican channels in Ku band on 7E which are an exceptionally easy catch in Europe as well
fif
Dreambox 5620,
Dreambox 600,
Openbox 810,
T90 8°W<>28°E,
Germany/Holland
Thanks a lot!:) What kind of programs are they in 7° west?
Turok
1,25 Fibostop
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Austria
for e.g.
_http://africable.net
a very good musc channel,sending also on 53 west in cband,in past it was on a intelsat satelite,in cband,then swtiched off over 2 years,and then this great african music channel comes back,to 7 east in kuband
guest poster
registered
Turok said:
..............make sure,that is right closed,if it not cloesed 100% corectly,water comes in,and your lnb will be fault!
Most C Band LNBfs are designed for prime focus dishes and many have drain holes in the face cover which, on a prime focus dish would face down allowing any moisture to drain 'out'... used on an offset dish they face up so rain can get in... those holes need to be sealed or another cover material used over the whole face and the rim sealed properly.. all with material that won't effect the c band frequency.
