kamaleon
- Dec 2, 2005
- Age
- 54
- skystar2 pci skystar usb + porty lidl camping dish maybe one day i'll have a dreambox 500s...
- str8 frum da wesside innit?
Hi folks,
C-band n00b inside, so sorry for the following n00b questions.
Basically, I'm beeen thinking of trying out C band on an offset dish.
Can anyone recommend C-band lnb brands that I can order in Europe? Which particular brands? I understand inverto make some, are they any good?
2nd question: Can i fit a C band lnb on a regular 40mm lnb holder? I understand a C band lnb comes with a feedhorn, what diameter are these usually?
3rd question: I've seen there are a couple of feedhorns for C120 Ku lnbs that look like the C band feedhorns. Are they the same rings? Can they be used for C band? like here:
_http://www.multimedial24.de/shop/d_30101.htm
4th question (it's getting more complicated now !) I would like to do it on my 90cm fibo dish. Is this possible?
thanks ever so much :-worship
