cam/ci slot
gladiator12
I have pinnacle pctv sat pro pci 450i dvb-s card running with no problem.im gettin signal from nss6 and many other satellite but want some other.I have p4 pc with 1.5 gb ram.
Punjab, india
Hi
I've dvb-s. Card. I want to know about how much approximate cam/ci slot cost for me. It is worth to buy this thing. I'm new to this please help me
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
I have moved your post from the four year old thread you posted on.
As you have a card I thought the card had to already have one, I am not aware that it can be added afterwards. What make and model do you have or is it as per your profile?
It is not possible for anyone to answer if it is worth it on your behalf, what do you understand its function to be? What would you hope to be doing with it?
gladiator12 said:
Hi
Maybe your PCI card doesn't have the facility for adding a CI module. Best to check with the manufacturer's website.
Others such as the Skystar HD2 and WinTV Nova HD do, maybe some DVB-S cards too.
Moved to the appropriate section.
BombedOne
Republic of Georgia
AverMedia DVB-S Hybrid A706R also has CI module connector, hovever, I was not able to see module for it for sale.
gladiator12
Punjab, india
Thanks all
I've card that I shown in my profile.
It support only fta channels. But I want to know is there any way I can watch pay channels those I'm subscribe
Ones again thanks
