cams compatibly list for PACE DS810XE HD,after software crash no cams acepted!?
Turok
1,25 Fibostop
Jäger Smr 1224 & Smo 36 Dual Axsis Motor
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Tagra 2,20 M Fullsize Dish
Echostar 2,40m Mesh for cband!
Austria
Hello!
i have bought an PACE DS810XE hd,one week ago,but this reveiver is very strange,on net i read,is it incompatible to diablo cam,when i iserted 5 days ago,picture was full of pixel,and interruption sound,one day later,the massage,shows ,my cam is not compatilbe with this reveiver,
my tirex,website told ,on google it is compatible,i inserted today,try to aces menu but only see please wait reveiver hanging.
now very strange,today i am watching fta channels,then sudenly,the complete picture,was violett,on my hd plasma,5 minutes later the reveiver crashed,skart output was black,nothing hapens it boots,i see the channel name in the display
one hour later,i replug power,reveiver picture comes back,but from this moment on,no cams are acepted,i insert cam,and it showes no cam inserted,so what could be vault?
does anyone can tell what cams should work on this reveiver
i tried with diablo/ tirex/dragon joker,freecam,and zeta cam,nothing works:(
maybe my ci slot is gone,or it is software fault,how can i make factory reset,on this pace?
first digital pace that i have,since d2mac time,remote controll looks very good quality,but thats all...
Mickha
North West
Hi Turok,
I have found this information on your receiver:
A software update (v1.0.21) for the Pace DS810XE High-Definition set-top box is available on the following satellites:
  • HotBird @ 13.0°E: 12476 H 27500 / PID 1999
  • Astra 1 @ 19.2°E: 12148 H 27500 / PID 2402
  • EuroBird 1 @ 28.5°E / Astra 2 @ 28.2°E: 11428 H 27500 / PID 2402
To download the new software please enter the 'Setup menu' and select 'Software update'.
Next select the appropriate satellite and ensure that the transponder parameters match those given above.
Then press <OK> to start the update.
The download will take several minutes, during which time the box should not be turned off.
After the download is complete we recommend resetting the box using the 'Factory Reset' selection in the 'Setup Menu'.
This will erase all the stored user settings. Please note that this step can be omitted, for example if you want to keep
your own channel lists.
You could skip the update and just try the factory reset in the set up menu.
For further help and support check here:
_http://www.pacemicro.com/corporate/content/webcontent.asp?nav=products&fullid=products_810xe_support
