Can i get a viewing card for GINX ESPORTS TV
Sateal
I have a ferguson ariva153 COMBO box
County meath ireland
Hello everyone.
Is it possible to get a viewing card for GINX ESPORTS TV. I have a Ferguson ARIVA 153 COMBO box and I live in ireland. Is there a company that make up viewing cards for a single channel.
Unfortunately the answer is no, you'll probably need to subscribe to the basic Sky package in order to receive it from satellite, assuming the Irish Sky packages are similar to the UK ones.
Alternatively it looks like you can stream content from the GINX website:
https://www.ginx.tv
If you can point your dish to a different satellite, there's a free channel on Hotbird 13°E called ESports Revolution that shows video game content. Advantages over GINX is that it is broadcast in HD and 60hz, so there's no juddery frame rate conversion.
astra19
98cm motorised technomate. 50e to 34.5w
Europe
Related, is there anyone else with problems with ESports Revolution TV? I can hear the sound but I can't see the picture. Vu+ Duo 4K SE.
Working fine on an Edision Primo :)
As above, audio and video working fine on the cheapest 1080 box I have here (Dynavision DL300), 20210810_114023[1].jpg
statalite
SF8008
DiSEqC motor with 1m dish
Zone 1 @ 28.2°E
Zone 2 @ 28.2°E
SMR 1224
UK Midlands
Try changing your video output options to automatic or similar as someone said this is broadcast at 60 Hz.
Sateal
Hello. I'm sure thread might be to old but, could you tell me if there is a viewing card I can get for a ferguson ariva 153 that give any good entertainment or sports channels.
Things to consider
1) what EXACTLY are you interested in? Entertainment & sports is a very wide description
2) If you only want English language then in you are in the UK/Ireland get Sky for the biggest choice of channels.
3) many pay tv services require dedicated receivers these days. Or at the very least require CI+ cams, many receivers are not compatible with CI+ cams.....
Is your dish fixed or steerable ?
If the latter, what is the range east to west ?
Sateal
@Analoguesat what services are available with dedicated receivers
Im not going down that rabbit hole until you decide EXACTLY what you want- just accept some services require dedicated kit
What size is your dish? If its a smallish one then your choice of satellites is limited.
