can somebody helpme
PICKLE
i am going insane ryingo prog a blue tit card please help me
jimbo
Retired Mod
Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
Greater London
We need more info pickle. Like which programmer for instance.
PICKLE
I Have A Infinity Phoneix In Phoneix Mode And Tit Prog V 1.10 Load The Files Ie Erase Card, Load Epr, Load Flash, Burn Tit Card (blue).
I Then Place In Seca Cam 1.5 Message Comes Up Error With Card Please Help Me Pls Pls Pls
jimbo
Retired Mod
Greater London
Sorry just got back on Pickle. The Seca cam may be the problem. Is it V 1.03 or 1.05? I presume you are picking up Seca2 files. There have been some key changes though. Do you have a matrix reloaded cam?
PICKLE
no i havent jimbo i have to secs cams 1 is v 1.4 and the other is 1.5 feel like throughing it all in the bin, it is so frustrating, on prog v 1.10 wot do you put in the crypt key section all the files i have seen have only hex an epr and they are the only zipped files im burning to the card pls pls help jimbo
You don't need to enter a cryptkey Pickle, but you may need to run the files on an earlier operating system of the card, some CAMS will only respond with OS 1.03. Having said that, there is a risk of breaking the card with the downgrade, so you need to weigh up the pros and cons.
PICKLE
I Have Tried Updating It And Downgrading It No Joy, The Files I Have On Supposed To Work With V1.10 Software And V1.06 On Tit Card
No Joy Please Help.
Could The Card Be Faulty It`s A Blue Tit With Hologram On It
Unlikely to be the card, if it programs properly without error messages, then it is probably OK.
It isn't so much what the files like with regard to operating system, it is more what the CAM likes, but if you say you have tried 1.03, then that won't be the answer.
jimbo
Retired Mod
Greater London
I could never get Seca2 to work in an Aston 1.05 but the same card no problem in a MR.
PICKLE
how does the mr work with a titanium card hlp me understand at the mo i have spent hundreds of pounds on programmers and cams (seca) blue tit card and all i can see is that black tv can someone help me see light of day please pretty please
