Can you receive ARMENIA TV?
ormoslo
Can anyone receive this channel and which pids use?ARMENIA TV on W2 16E 12725V 3418 2/3.
Satdude
N/A
Ireland
Eutelsat W2 - 16.0E
Armenia TV 12723V SYM:3416 FEC 2/3 SIDO VPID776 APID777 Ar
No problem here 16 East can be a little weak, depends on the size of dish etc, but it could be outside the range of your LNB?
Regards SATDUDE. :D
ormoslo
When I search this frequency my NOKIA store the channel but I can't get any pitcure.I have 70-80% signal
Without knowing where you are Ormoslo or which satellite equipment you have outside, its very difficult to give an educated guess on what is preventing you from seeing the channel
ormoslo
I have 1,40m dish and I ask becouse this channel mark as FTA but many receivers can't receive it.
G
GotMyBusPass
Hi
My receiver shows no channel for this TP , strength 70%, quality 36%, east anglia, 98cm dish. As Channel Hopper states, it would be nice to know where abouts in the world you are located.
GMBP:)
Lumezit
I have the same problem with Humax 8100 CI,120cm dish and a 0,7 LNB. Armenia Tv is out of my range. Eutelsat Strenght 70 Quality 90 )(-red
caretaker
If you just put the vpid in and nothing on the audio pid you may get the fta...good luck
