card and'''
caretaker
please help... i have now got a fun card and a programmer But do i still need a cam for the card??..or should it still work in the card slot on receiver..Receiver=nextwave 2500 C I EMBEDDED..Thanks guys ..)(-red
rob43
canaries
hi caretaker. no you won´t need an extra cam. just put the programmed funcard in the top (card) slot. i have the same receiver. do you know what version you have? if you have a look in the info section on the menu it should tell you. rob43
caretaker
Hi Rob..Thanks alot .The version i have on the receiver is V.2.27.A Oct23 2003 Thanks again
