Card programming - missing channels
G
Gazzah
I have just for the first time successfully programmed a Q card using my VX Multi for the seca cam but unfortunately it hasn't programmed all of the channels that i normally get when i buy a card from the shop :(
Does anyone know why the Kiosque and Cinecinima don't work on my newly programmed card?. If i put my original card from the shop back in they work.
Could it be something to do with the Seca file i downloaded from Phills site not having the Kiosque codes etc? The Palco and Tequilla channels work fine but not the others.
Hope to hear some news soon
Thanks alot
Gaz
P.S. I was really chuffed to program the card at only the second attempt. My ego though was slightly knocked when i discovered some of the channels not working.
2old4this
Honorary Admin
Cloud Cuckoo Land
What's a "Q card"? Is that a 16f876/62x based card? If so were you using DS9 software? Or was it a funcard/Jupieter2 with 3-in-1 software? And which CAM? Those cards in an Irdeto CAM (freeCAM) will not open up all channels. Limitation in the software (not the keys as such).
2old
