card timer reset
ahmedmakki
Star-sat SR-X30u usb
Hi There,
I have an ART Arabesque card working great on my receiver. The card comes to expire very soon.
Is there a way so I can:
A) update/change the time of my receiver so the card doesn't now when to stop working.
OR
:cool: update/change the card setting (maybe by using card reader/writer hardware) to reset the timer?
thanks for your help in advance
Ahmed
No - you will have to resubscribe and do it properly.
ahmedmakki
These card does not need subscribtion... they just got active (for ~12 months) once your insert them into your sysetm... there must be a way to go arround it and reset the timer.
So are you sure there is no way to do it?
Absolutely. Modern cards cant be tweaked like in the past, or we would all be doing it, all the pay tv providers would go bust and we wouldnt have anything to watch.
If you dont want to pay for another years access then you do without. Your choice.
