cccam sharing
ritzik
dm7000s+dm500s
SWISS
Hallo can somone show me how to share with cccam from dm 7000 to use with dm 500
i dont know the config file how to
ps need national geo channel what card must i buy
ritzik
Post split from the topic you had posted in as it wasnt relevant to that discussion
A nonymous
ritzik
Which National Geographic are you talking about mate. Its on virtually every Satellite up there :-sugar
If you have a look in Var/Etc on either 500 or 7020 you will find a file called cccam.cfg, you might be able to figure it out from there :D
I don't use CCcam so i couldn't tell you how to set it up but it should get you on your way if you look in the file.
:-beer
Nano
PetSat
WinXPProSP2
Under the HB beam
I hope this will help
CCcam and cardsharing
To configurate and connect the CCcam, you need to go to the ETC folder and edit the
CCcam.cfg file.The CCcam config file itself is a little help file. Indeed, you will find many text
lines starting with #. These lines provide help to set the CCcam, and there is no need to
delete them as they are ignored by CCcam. Therefore, they can also be used to add any note
or comment.
The configuration lines can be written in any order. There is no standard order to respect.
Indeed, when started, CCcam reads the first character of each line and executes the request.
Let’s look at each line syntax now.
F: Friends
F: user1 pass1 1
C: Connect
C: server.dyndns.org 12000 user1 pass1
The C line (where C stands for connect) enables the CCcam to connect to another server
The URL or IP after C: is necessary to identify the server in the sharing network. 12000 is the
port used by the server to communicate and user1 pass1 identify the user
Note: each user is accepted only once by the server
How to connect a client to a server:
The F line launches the server, whilst the C line launches the client, and this is all you need.
Should the client wish to share its subscription cards with the server, then you need to add a
C line at the server, and an F line at the client.
Log Diagnostic
Should you wish to check whether the connections are working properly, then use the CCcam
–dv Telnet command. This option will give you the possibility to check the log and make sure
all is ok.It may be useful for beginners to do it with Telnet, and, once experienced, it may also
be done using the the automatic script found in the blue panel.
Cam log removed - admin
ghalqa
humax 5400
can someone help me I want to conect my two dreamboxes with the same cline.
i do not know how to do it
can someone help me please
T_G
The Consumate Dreamer
1 GigaBlue Quad plus, 1 Dreambox 5620, MOTECK SG2100A DISEqC Motor, 120 cm noname offset dish, Humax 95 cm offset dish and a few UK digiboxes.
Somewhere where the Sauer is Kraut and the Wurst is Brat
There are quite a few threads about card sharing problems. There is also a tutorial about card sharing in the guide section. If you have a specific question that is not covered yet, then you need to tell us. Also, what have you been doing so far, what happened, etc etc. If you want help, you got to help us help you :)
B16MCC
Dreambox Gimp & Coder
2 Dreamboxes..........
--- DM 8000 HD PVR & DM 800 HD ---
Motek SG2100 & Triax 80cm Dual LNB
------ Fixed Dish 28e Quad LNB -------
---- Sly HD Full & 24" Apple iMAC ----
/var/tuxbox/config
Ok guys, a few pointers to get started.
1. Read my guide 5 times.
2. Don't be scared by the CCcam.cfg file , its contains loads of info you don't need
3. If you want to share 1 box to another , your config files are just 1 or 2 lines thats all.
D
deleted
hi sorry to be a pain
i have followed most of the threads on sharing my card with a friend, for days now and was hoping to crack it myself
i thought i had done all the relvant files and so on, my card is working ok
in my tm500 with ur 13082009
using cccam2102+newcs1.67.
when i telnet and CCcam-dv i get -sh: CCcam-dv not found !!!
am i missing a file in the scripts ! what am i doing wrong
i have my f lines and clients clines in both boxes.
thanks for any help:
compufunk
DM 600-S, VU+ Duo,
Moteck SG2100, Fracarro Penta 85 dish, LG LH3000 42" TV + some computers
NW, Ireland
First of all you need to use a space between the command and the switch.
use
CCcam -dv
instead of
CCcam-dv
You may also need to use the full version name i.e. to start CCcam from the command line I would need to type CCcam_2.1.1
To find it on your system, run the following command.
 find / | grep CCcam
Its probably in /usr/bin/ or /var/bin/, but your file structure may differ from that of the dreambox
D
deleted
yes i have tried CCcam -dv with space still get same response
i have reloaded nabilosat image for the tm 500 new and still get the same when i telnet CCcam -dv now usin CCcam 2.11 +newcs 167 white card works ok
i must be misssing something ?
compufunk
DM 600-S, VU+ Duo,
NW, Ireland
Yes, but are you even sure that the file binary file is called CCcam?
As I already mentioned, find the file by running ....
find / | grep CCcam
shumifan50
2xDM7025(DVB-S tuner), DM600SPVR, DM800S, DM500S HD, Triax 90cm with MultiBracket 4 sats.
Europe
Better to run "find / -name CCcam*"
compufunk
DM 600-S, VU+ Duo,
NW, Ireland
Not really. That will only find files called 'CCcam'. It wont for example find a file called CCcam_2.1.1 or CCcam_2.1.0 or whatever. Which is how they will be named by default.
shumifan50
Europe
Note the * at the end of CCcam, that means it will find CCcam......
compufunk
DM 600-S, VU+ Duo,
NW, Ireland
Ooops, Missed that. Its much of a muchness in any case. The output is the same.
A nonymous
Blimey, have you seen when the first post was made, back in 2007 when i was using gBox :-lol
D
deleted
hi again
have tried telnet. find -cccam*
result !!
busybox v1.2.1 (2006.10.11-21:54+0000) multi-call binary
usage: find [path...] [expression]
i cant get my head round this
shumifan50
Europe
This is not windows - file names are case sensitive to start with. Further spaces cannot be imitted. So type the following EXACTLY is it is
find / -name CCcam*
Dont leave spaces out or insert any spaces and CAPS ARE REQUIRED
compufunk
DM 600-S, VU+ Duo,
NW, Ireland
You can just copy the commands from this webpage and paste them into your telnet sessions console.
D
deleted
ok so that command worked .
shows me directories /var/bin etc.
shows me that i have CCcam etc.
so where do we go from here !!
i know i have CCcam + newcs because their working on my old **** card on ***
i just need some easy steps to set up a share with my m8
sorry guys if i sound a bit thicko, i can assure you not .
got my port forward working , dyndns account setup and updater
CCam info pages are up on browser
where am i going wrong
thanks guys.
