Pincera
- Sep 21, 2024
- Age
- 71
- Sky Q, Freesat 4k box
- midlands
After 25 + years I have decided to move away from Sky an have purchase a Freesat recordable box and it works fine.
I noticed on my TCL tv that it had a "F" button on it and above it are the words Freesat Play, which I understand is an on demand service ! The TV also has an F type connector and has a satellite symbol above it, this confused me so I contacted the manufacturer to clarify the type of tuner within the TV.
This is their reply
Based on our information, the TV does have a satellite tuner and should be compatible.
This model has the following specifications:
The reply has added to my confusion as I understand the "T" in DVB-T2/C/S2 denotes Terrestrial, my understanding is this tuner only receives Terrestrial signal rather than satellite signals.
My plan was to use the Freesat box in our living room and if my TCL TV, in the conservatory, supported Freesat I would change out the Dish Wideband LNB from a duel to a quad and run a single coax feed into the conservatory and use my TCL TV, in the conservatory. There little point in this if the TV tuner does not support Satellite signals!!!!
I may be the one who is confused so I would be grateful for the input of someone who has a greater knowledge of these things than I do.
This is their reply
- DTV Tuner: DVB-T2/C/S2
- Sat: Diseq / Unicable: Yes (V.2.2.)
