Dggrr
- Sep 2, 2006
- Age
- 70
- VU + Zero, Triax TD88, Technomate TM2600 (Plus CM 1.2 in bits behind the shed)
- SE
I've just replaced my CM 1.2 with a Gibertini OP125L, so am offering for collection from West Herts (HP4 1ED), separately if wanted but definitely collection only:
- CM 1.2M dish face. in OK condition but painted Sadolin Cappuchino (sic!) to match my shed!
- CM LNB arms for above
- 3 * CM LNB holders and 23mm adaptors, at least one with no bolts
- CM AZ/EL mount (possibly also suit CM1.0 and 0.9 meter dishes?)
- CM Feed horn
- C/KU BSC621-2 C/Ku band LNB with scalar rings for centre fed and offset dishes, never worked on the CM1.2 or TD110 for me. PDF attached.
If no takers then off to the tip in a few weeks.
- CM Feed horn
