Channels OPEN again in Starsat Now
pmmali
Multivision,TPS,BBC Prime, W9, RTL9, XXL, Xdream, Absat Pink TV RAI
and too many scrambled channels in Hordbird are working now on Starsat 550
( i dont try in another receivers)
My receiver Starsat 550 V225 another receiver starsat 550 convert to sonysat
Regards.
DeepDiver
Vista- DreamBox 7020Si Nabilo Darkstar II -7025+ Black Hole 0.11 - DM8000 BlackHole 0.11
Mariana Trench - Pacific Ocean
Confirm that on my starsat 650 super with v337....but no ABsat
pmmali
Yes sorry Absat is not work. but any one channel name same like ab its working i dont remember the correct channel name.
Regards,
pmww04
hotbird, asiasat3, nilesat, badr, pas7, nss6
saudi arabia
yeah all channels working here in my technosat 200 too.
graovacb
Starsat SR 550, dish 130 cm fix
Serbia
Sorry gays I was absent for a little and now I can't catch the point. Does it mean that you can watch all that channels permanently or the keys have to be changed continuously? I suppose you know that TPS e.t.c. are changing keys every 30 min.
imlucky
starsat receiver
rawalpindi pakistan
i have starsat SR-X3100CU ULTRA,and unable to receive multivision package,spice platinium and some other channels can u help me to upgrade my software or direct me how i can access these channels on my receiver,,waiting anxiously for your reply
imlucky
starsat receiver
rawalpindi pakistan
i m lucky but only by nick because having problem in receiving some of my favourate channels like MULTIVISION x or spice platinium on my starsat SR-X3100CU ULTRA recive,Can anyone help me to upgrade my satellite software of direct me otherwise how can i enjoy these channels,,waiting for your answer
DeepDiver
I doubt you'll find anything that opens TPS, Multivision, etc, on your box.
The first 3 posts in this thread refer to a week where TPS was using an old Viaccess encryption system, rather than the AES. And therefore, thos channel would be clear without any pathc or update.
Now, they've gone back to AES and keys change every 10 or 20 minutes.
imlucky
starsat receiver
rawalpindi pakistan
Its nice to c your reply, coz surfing the browser for the said software just made me go crazy,
But now i m sure that those channels will be open as soon as they will be allowed to with my existing software,hopefully v v soon,,,once again thanx
imlucky
starsat receiver
rawalpindi pakistan
First of all i must say thats members here are so much responsive and this thing really encouraged me to share a bit more with you people
I want to know that what does a software upgrade does to your receiver,does it only changes the frequencies (adds new frequencies) or it also upgrades encryption systme of your receiver...because with my existing software i m unable to view channels using AES .
DeepDiver
Software patches usually upload the latest available keys, or any upgrade of the existing encryption systems.
Currently, you won't be able to watch any package using the AES encryption system, regardless of the patch you upload.
To add the frequencies of newly added channels, you can do a manual scan, or your can download the frequencies from satcodx.com and upload them to your box.
You can also do a search within this forum; you will find that your questions have already been answered in the past.
Hope it helps.
imlucky
starsat receiver
rawalpindi pakistan
THANX Mr DEEEEP DIVER!
oblidged that u answered my question, and tell u what i uploaded new software for my box from SATDW.com and now all the TPS AES channels have come back but this time its not just for 2 or 3 minutes rather its for almost half an hour,,well i think its a bit better but u are rite that theres still no permanent solution for it.but channel PRIVATE SPICE doesnt come even for a glimpse,,,so any key plz if theres any.
with regards
LUCKY
imlucky
starsat receiver
rawalpindi pakistan
hi i want to find that when will multivision and other TPS channels will stop using AES?
mic4321
starsat, fortec star, echolink
U.A.E
Hi lucky,
I have also starsat 3100, can you please tell me the key to unlock the receiver, so I can enter the keys manually,
