clanzer build 5 Programmer
BKmagic
Does anybody know if this programmer will program titanium card ?
If so, what program should I use.
Thanks,
If it works in phoenix mode at 3.58 Mhz, then it should be OK, then yuo need one of the Titanium Progger software versions to program the card.
Sab
DM 500s
Gemini
Release 0470
CCcam 214
North Wales
You may have to do some adjustments to the programmer.
Have a look at www.minisdk.co.uk to see if your version needs it.
