Client problems
wannabee
Vu+ Duo with 1TB HDD, Vu+ Solo with 500GB HDD, Dm7025 with 80GB HDD & 1m Triax
Advent 9415 lappy
Co. Tyrone
Hi guys,
I have a DM7020 and everything was working well.. including my C/S.. now i am showing as offline to all my clients.. I still have the old blue s/y card in my box as i have not activated my 3rd white one yet.. I have 2 other sky boxes in my house.. and did not want to activate the last new white card until i really has to.. hopeing that a new cccam will be realised intime for the blue cards being switched off..
I can still view all my channels on my blue s/y card.. its just my clients who cant..
They all say that i am showing as off line..
I can connect through DCC and all is good there..
Does anyone have any idea what the problem could be.. ??
Thanks in advance for any help..
andel
DM800, DM600, Technomate Diseqc Motor, 90cm Dish
Panasonic 42" Plasma 1080p
Pioneer VSX-LX70 Amp
Sky HD
B & W 5.1 Speaker Setup
Popcornhour Media center
Xbox 360
Watching T.V in the UK
Does your router assign a fixed ip to your DB? Check that it hasnt changed the ip and the server listen port is being forwarded correctly
wannabee
Advent 9415 lappy
Co. Tyrone
Hi Andel..
Thanks for your reply..
I have just checked both.. and all is ok..
Do you have any other suggestions please.. ??
andel
Sky HD
Xbox 360
have you tried scanning your open port just to check, i know some routers have had problems saying they are open when they are not?
_http://www.auditmypc.com/firewall-test.asp
wannabee
Advent 9415 lappy
Co. Tyrone
Hi..
Thanks for your help.. I just deleted the cccam 2.1.2 and then re-installed it again and all is back working 100%.. I dont know why this cured the problem.. but all is back working again now..
Thanks again for your help..
