- Jan 1, 2000
- Age
- 60
- Website
- www.sat-elite.uk
- UK
I got called out to a job earlier (major roof leak meaning taking down the aerials and dish from the chimney whilst scaffold goes up) .
Waiting for the rain to subside I was asked by the client to look into the setting up of one of these - A Roberts Stream 94 - possibly 94i radio that they had bought in the interim, knowing they might be without television for a fortnight apart from streaming.
Hells Bells ! Whilst I can understand it is good to have everything in a small package, this was a nightmare.
Once past the opening screen I was presented with a requirement to acknowledge and accept terms and conditions of use, before I could connect to the router.
Then the radio went into an update which took about 20 minutes, before I could begin to tune in stations.
Two hours later I had some DAB stations scanned and preset onto the five front panel buttons, before turning to the streaming section........
Whilst it was interesting to look through the sheer number of available services, they are catalogued in really odd ways, not as I would have thought by genre or language. Lastly after finding three that might be of interest for the client, I found these could not be added to the DAB 'favourites', but the client is expected to go back into the rotary menu from the tuning button, select the right protocol that is illuminated as a picture, then press select to gain entry.
Hardly user friendly when one is well past their three score and fifteen.
With luck FrontierSmart / Nuvola will see this and note the error of their ways, Roberts used to be a marque I could promote, this is one direction that has stopped that.
