code menu for IDdigital F22 sensor
craft_nemic
wazz up m8s ..
do you have the code menu for IDDigital F-22 Sensor that we can input the key inside and watch encrypted channel...
if you know where to find plss kindly post the link ....or give me some site where to download it...
Tnx in Advanced
PEACE
basel
craft_nemic said:
wazz up m8s ..
do you have the code menu for IDDigital F-22 Sensor that we can input the key inside and watch encrypted channel...​
if you know where to find plss kindly post the link ....or give me some site where to download it...​
Tnx in Advanced​
PEACE
me too I HAVE THE SAME PROPPLEM WILL PLEASE SNED THE MASTER CODE TO MY MAIL, THANKS
basel
Yes I Found What Do You Want Just Fallow The Steps:
1-press Menu
2-insatallation
3-status
4-stb Status
Then Press The Red/ Green/ Yallow/ Blue And Zero The Code Will Go To 0000
welshboy
Wales
Has anyonje got information if you can patch this receiver as it has a serial port on the back of it. Makes me wonder?
I believe its a humax receiver.
Any help would be appreicated.
Welshboy
feupeiro
FTE 420SM (foi foi..naquele tempo...)e ...Dream500s (foi foi ..há algum tempo)......500Hd e 7020S e mais nada!
Berg
Welshboy
Yes ...it is the same like humax 5400 & some others: HUMAX 5400 & SOME OTHERS
Menu- installation-ok-status-ok-STB status-ok then press on the following buttons-RED-GREEN-YELLOW-BLUE-WHITE- then press 0 now ur receiver is 0000
HUMAX F1-C1
Menu - status -STB Status - ok -press UP button at the front panel - i - press the button contain ( ? ) - press yellow button - exit now ur receiver return to 0000
DIGITAL TELECOM
0851 - 1004 - 3472
Stay cool!:cool:
welshboy
Wales
People have miss understood the question I worte. I was wondering whether the receiver can be patched with a null modem cable? with the hot/toh patches? so that keys can be pu to on.
Welshboy
