Comag sl90 hd
james01
Comag sl90 hd
England
i have a Comag sl90 hd and i have update from usb,but i have burned not the right file and now when i make power on there look channel 4 and ist blocked .i can't do nothing.Please help me!
james01
Comag sl90 hd
England
please can anyone help me!
Have you tried loading the right file?
james01
Comag sl90 hd
England
no,because this receiver it doesnt have rs232 just usb.and i dont now how can i load the other files.
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
If you have flashed the incorrect firmware file to your stb and the stb still boots then there is no reason why you cannot flash the correct file to your stb assuming of course that you have it or can obtain it. If the stb does not boot then the only other two courses of action open to you which are, to jtag the stb, assuming you have jtag connections on the mother board or can locate them alternatively bin the stb and buy something that has proper support.
james01
Comag sl90 hd
England
but can you tell more that what i need to do.and i have flashed with a usb stick and i have chosed file from receiver but at now i cant do nothing becauce is blocked.
Topper
You need to explain in clearer terms.....does the stb boot at all?
james01
Comag sl90 hd
England
it boot at canal 4 and then is blocked i cant manage with menu or anything else.
Topper
We seem to have a language problem here canal 4?????
as already mentioned if the stb does not boot then the only course of action open to you is to jtag the unit or return it to the manufacturer for repair.
james01
Comag sl90 hd
England
ok.but can you tell that how can i return it to manufacturer! Thnx
I see the problem with the language barrier. You arent in England are you james??
You are in Germany from your ip address.
Please fill your profile in correctly - it can be important for some technical questions.
The best thing you can do is contact your supplier and see if they can help you.
Unfortunately there is a good chance you have learned the lesson about loading an incorrect file the hard way and wrecked the receiver.
james01
Comag sl90 hd
England
okk.thnx for helping me!
