djdeejay
- Aug 23, 2009
- Age
- 40
- SKY HD.
- Chester
Hello everyone,
I have registered and paid for Sky HD in my apartment and Sky are coming 31st of August - prior to then I need to solve the problem with my apartment only having one lnb feed.
I live in strange block of apartments in Chester, I am in a seperate block with just 14 apartments in - the top 7 of which mainly have their own sky digital dishes so as not to use the communal system.
Ive found the dish on the roof which is accesible to everyone, has a quattro lnb and feeds straight down the building (about 8 floors) into the car park in the basement where it joins its multiswitch box.
Im yet to poke around there - but the box is always wide open, I cant quite see in - but i see the four cables in and then all the cables leaving for the apartments. I cannot count the amount yet - tomorrow i shall be up on the ladder to investigate, brands, numbers of leads etc.
I currently have a Sky HD box just viewing the free channels - the quality of signal I admit is not great. I currently have a "booster" from maplin on the cable in my apartment and I have just under 50% of signal strength and exactly 50% for quality on sky.
I traced our cable where it enters the bottom of our apartment, and its about a 35 meter run - but I would estimate its probably 40-45 meters by the time it reaches our wall socket.
If i can find a spare feed tomorrow - which im sure I will, and certainly be able to arrange to use one of a neighbour as no one has sky in the bottom 7 flats - what are the chances with such poor quiality to start with having a working feed?
Ive been told by this link "http://www.satcure.co.uk/accs/stacker.htm" that i need a Johanssen 9639KIT for communal use and not the standard stacker/destacker - is this true? Or will any Johanssen stacker/destacker work when supplied with two feeds from the multiswitch? The reason I express concern at this statement is because I cant actually find reference to the 9639 anywhere on the internet apart from their website!
The 9637 wideband amp is mentioned on the page, to be used at head stage - is this correct? Should i use it just after the multiswitch and before the stacker?
Also - many people say not to use a wall-plate. Obviously all the apartments terminate with a faceplate in the wall. Would i just be able to remove the faceplate and replace with a fconnecter to go straight into the destacker instead?
Using this before the stacker, and then a 60m rather high gain stacker could i even possibly improve the signal from what i currently receive? I dont have any problems on channels - I used to get them on Setanta only.
I will report back when i know more about the multiswitch and what feeds are available and if i can even trace my cable (if they are not numbered i will do my best to trace...finally resorting to just undoing each one to see which is mine - I only have 14 to go through!)
If someone could help with a few of the questions here, and also - the power for the stacker/destacker, do they plug into the stacker end, or the destacker in my apartment?
Look forward to some info and feedback, ive read every thread I can find on the website here to get most of the information I already have - so any input on the questions I have asked would be fantastic.
Kind Regards
Kind Regards
