Communal dish - single feed
baldmosher
Communal block dish (unknown)
Humax Foxsat HD
aiming for a dual sat PCIE tuner card....
Salford, UK
Rooftop dish and single feed into the flat.... will it be possible to install a dual DVB-S2 tuner in my HTPC setup or must I stick to single feed? My suspicion is that the simple answer will be a flat no, and that's not a massive problem since I can install a DVB-T2 tuner card alongside a single DVB-S2 tuner card for total ~£100, so it'd have to be a cheap option even if it's possible. Thanks in advance!
Rick
Retired Mod
Fibo 1.2m HH, Wavefield T90. AzBox HD Premium, Vu+ Duo
Blackburn, Lancs
It depends on the system. If there is a spare output on the multiswitch you can stack a second feed down the cable into your flat.
satelliteman
As above, subject to a spare feed on the switch, you can use a stacker / De-stacker unit. If it's a communal system, then you'll need to speak with the management Co.
More info from one of the site advertisers _http://www.sateuropa.co.uk/product_overview.asp?prod=Global-Stacker/Destacker-30m&id=1725&catid=16&subcat=61
