geoff lee
- Aug 27, 2008
- Age
- 72
- 90cm technomate 1500 essex uk/ 1mt pace digibox playa flamenca costa blanca
- essex/costa blanca
HI got a problem with our system, we have a 2.4 prime focus, invacom quad lnb , a golden interstar multiswitch, a problem occured a few months back, the channels on h low were unwatchable if we disconnected the input to the h high we got h low back, we tryed running a replacement cable to h high still no good, we were then told its a fault with lnb , so we changed the lnb and had same problem, could it be a falulty multi swich or is it a question of balanceing the signals could a stronger (h high) knock out a weaker ( H LOW) is there any thing avallible to weaken the stronger signal, another strange thing is 12523 v (SOLAR RADIO) is not there at all no signal and this is normally strong you can get this on a 80cm on the costa blanca, on ideas what going on thanks any help would be good
