compro lnb settings
portly
Bush freesat hd box, iss 70cm dish,single passion lnb , goodmans GDB15HD freeview box
heathrow
Im trying to get compro DTV2.5 to access the hd frequencies, which at the moment it wont, for some reason it jumps the frequencies.This maybe down to the lnb settings?
I have a universal ku band lnb with the following in and outputs
Input : 10.70 - 12.75 ghz
Output : 950 - 2150 mhz
Below is a piccy of the compro setup scene. what settings should i put in the lnb section. i have a single dish and lnb fixed at astra and eurobird 28.5
Thanks Gaz
Does your card have a DVB-S or DVB-S2 tuner? If the former, you won't be finding any HD channels except possibly those using DVB-S and MPEG4 video (such as ITV HD).
portly
heathrow
Hi Llew
I can get bbc hd itv hd (finally)and luxe hd with dvbdream but not with the compro software itself, for some reason it jumps past the bbc hd frequencies when you do a simple scan and dosnt show up when you try a transponder scan? me thought it might be the lnb settings.It is a dvb-s card
Cheers Gaz
LNB settings are OK. Can't see what your problem is there. You should certainly get the other channels on the10847V TP.
I'd stick with DVBDream.
