Connect 5 satellites to two dreambox 500hd
03397
Hi guys. I really need your help because I am lost.
I am trying to connect my 5 dishes to two different dreambox 500hd.
I have used 5 twin lnbs and two S8/1PCP-W2 EMP centauri switches. I am using the Diseqc 1.1 on both swicthes since they have dip switches.
I am really confused on how to set this up in my dreambox advanced settings.
I am sending you the settings that I have done on both receivers for the 5 dishes. I have used LNB 1 through 5 and for uncomitted commands input 1 to 5 which corresponds to the LNB number.
The satellites in order are Astra 19.2e, Eutelsat 16e, Hotbirg 13e, Eutelsat 9e and Nilesat 7w.
I will really appreciate your help.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
I think if you change Commited Diseqc command to 1.2.3.4 and 5 (usually it goes A, B, C, D and than 1,2,3,4......). And uncommited set to None, you will need it for cascading.
03397
Can you please be more specific what I must do because I am lost...
RimaNTSS
N-E from Riga
03397
RimaNTSS said:
see attached
It does not work.
Before it was locking most of the transponders but not all of them. Now it does not lock anything.
RimaNTSS
N-E from Riga
If transponders were locking than where is problem? Just scan all satellites. If not all of transponders are locked than it is issue of tuning antenna not diseqc.
03397
The think is before that it was locking the transponders, one receiver was finding all the channels except the sky italia HD channels and Nova Hd channels(I do not know If i missed other channels) and the other one with the same configuration was not locking the trasponders that the first receiver was locking. I am using on both receivers the configuration I have sent you.
This is how the problem started. Just to let you know that this set up never worked in the first place.
RimaNTSS
N-E from Riga
Try to change Command order to Commited-Uncommited-Toneburst and than Commited Diseqc commands 1,2,3,4 and 5. Uncommited - None.
03397
I did that.
My question is does the twin LNB need special configuration?
I am sending you the liflet of the switch
  • diseqc.pdf
RimaNTSS
N-E from Riga
Each output of twin LNBs it is lake 2 separate LNBs. Basically no difference if you use single LNB or one output from twin LNB. No specific configuration needed.
03397
Do you have any ideas now what to do that I have sent you the liflet of the switch?
RimaNTSS
N-E from Riga
I would try all possible variations. I never had 1/8 diseqcs, only 1/10.
03397
What kind of configuration have you used for your 1/10 switch?
RimaNTSS
N-E from Riga
For stand alone Diseqc 1/10 I have configuration like showed you in my post #4
Diseqc mode- 1.1
Commited diseqc command 1.2.3....10
Command order - Commited-Uncommited-Toneburst
Uncommited diseqc command - None
That is on my old good DM7000 which I lent to my neighbor, therefore can not make a screenshot.
On DM8000 I have cascaded 3 diseqcs 1/10 after dieseqc 1/4
