Connector on the 820t2 dongle
What is the official terminology for it ?20181108_113624.jpg20181108_113635.jpg
pontiend
Contibruter
south yorkshire
I thing that it is am SMA connetor though I have no idea what |SMA stands for.
SMA is threaded, and slightly larger. This has a push fit system with a clamping arrangement very much like the fastfit F-connectors. Outside diameter of the female connector is 3.2mm (+/- 0.1mm), SMA would be around 6mm.
aceb
Prof Tuner 7301 /
Sussex
Terryl
Custom built PC
Adapters arrived a minute ago., so I can bolt some external kit to the dongle.20181117_121637.jpg
aceb
Prof Tuner 7301 /
Sussex
Bear in mind it doesn't take a lot of BII to overload them a notch filter for the band is often advantageous.
The discone I have will hopefully raise the signal somewhat higher than the background noise. Will try tonight if there is a pass as I've just run a new aircored cable down from the roof for this specific job.
Terryl
Custom built PC
You should also use a USB extension cable, the dongle has a tendency to rock out when the cable is stressed.
I used about a 3 footer, this gave me room for mounting it on a heat-sink, and also for adding ferrite beads and shielding as thes things create some RF noise themselves.
It sits on a weighted extension, courtesy of an old style desktop connection antenna from a few years back.
Todays experimentation hasn't gone well though. Not sure what is going on signal was a good 15dB above the noise level all the way though apart from a couple of minor interruptions
Terryl
Custom built PC
What was the audio level output???? If too low it will look like that.
I find that it needs to be around 50% or better.
Ah. Im having to change from speaker audio to the virtual vbcable in order to commence scanning otherwise I get nothing.
Will check levels.
