- Mar 29, 2004
- UK
What options are there to control a remote motorised satellite dish over the internet? By control, I am referring to having the option to select various satellites and get the motorised dish to move to them.
The only way I can currently think of is to have software such as Prog DVB or Crazy Scan installed on a PC located at the same site as the dish and use this software to control the dish via Diseqc to move to various satellites. The remote PC could be accessed using software such as "PC Anywhere"
The only other options I can think of would be to have a positioner unit at the location of the remote dish that can accept an internet connection via a LAN port and is configured with some type of web interface that allows control of the dish. I dont think that there are any consumer grade positioners capable of this but there are probably commercial grade units that can do this?
Alternatively, some type of serial port control via an RS-422 port might be an option?
Rgds
Rgds
