The current requirements of a normal 36V actuator (and the dish they are moving) would probably prevent it .is it possible to convert a 36volt motor to diseqc
Best regards
I have a SMR 1224 H2H.
oke it is 12 Volt ,but can i make is to diseqc.
Mvg
Best regards
I have a few of them, they may be a different model though. Will check the board/chip firmware numbers tomorrow.I dismanteled all my diseqc rotors for those pcb’s . Not a single left
Apologies for the delay in replying, this is the circuit board I have a few of.I have a few of them, they may be a different model though. Will check the board/chip firmware numbers tomorrow.
Super goedExcuses voor de vertraging bij het beantwoorden, dit is de printplaat waar ik er een paar van heb.
Ik kan verzenden tegen verzendkosten als ze van enig nut zijn.
I have a few, probaby 30 or so.If they are no use to Mr Dish I like to have them
I'll pull out the boxes later in the week and grade from good to not so good. I remember some had the connectors removed since they were used on other projects.Great , If it’s no problem I like to have 5
