couldnt mount HDD (selevision)
grimed
Hotbird,Nilesat & Linux
kuwait
hello,
my brother consider him self computer geek but now i doubt his skills
well i got selevision which is the beast nd it has 80gb harddisk.my bother recorded some of his favorite shows and wanted those in his computer so he took off the harddisk nd run it in Xp which didnt work (of course as EXT3 doesn't work in windows).stupidly he formatted the HDD in EXT3 file sys through gparted but now when i connect my HDD,my set-top box isnt detecting my hardisk
it gives this kinda msg "(error hda);HDD is not mount"
pls help me guys
satelliteman
Post moved from dish set up section.
Mickha
North West
Check your instruction manual as it probably needs formatting correctly, check if you can do this with your receiver or if you have to do it in the computer.
From reading most hard drives require fat 32 instead of NTFS, which is probably what he used to format it the first time.
grimed
kuwait
thanks for reply
i tried all these file sys "FAT32,NTFS,EXT2,EXT3,EXT4 nd XFS"
grimed
kuwait
grimed said:
thanks for reply
forgot to tell you that these all formats are giving me the same error :(
Mickha
North West
Have you checked the manufacturers website for information? Usually it's in the FAQ's section.
grimed
kuwait
i tried that also but i think they are not into business anymore,i am totally hopeless :[
grimed
kuwait
selevision is some how like dreambox,does any one know what peeps do in those kinda sys to mount a harddisk???
Selevision are still going:
-http://www.kmanagement.net/selevision/en/Support/Support-Home.asp
grimed
kuwait
i saw it already but they have not give anything related to my problem :(
grimed
kuwait
do i need to edit the cmd line in the sys to mount my HDD???
Do a google search for (telnet mounting and formatting hard disk).
grimed
kuwait
i did tat also nd failed once again.thanks for the feeds guys.i gotta buy new reciever
