Log in
Register
Menu
Log in
Register
Home
What's new
Latest activity
Authors
Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Forums
Satellite TV receivers & systems support forums
DISH SETUP: Single sat, Multi-Sat & Motorised
Crap wall, wall plugs, bolts - HELP!
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Zed" data-source="post: 746002" data-attributes="member: 369096"><p>I'm afraid it was my own stupid fault. I had the bracket from on old 80cm, so I thought I'd try the td88 on it. Not the smartest idea I've ever had. Ah well, none of that matters now anyway, hopefully I'll get a proper install done soon. :-)</p><p></p><p>On that note, can an admin please enable my PM facility so I can make contact with an installer? Would be much appreciated. Thanks.</p></blockquote><p></p>
[QUOTE="Zed, post: 746002, member: 369096"] I'm afraid it was my own stupid fault. I had the bracket from on old 80cm, so I thought I'd try the td88 on it. Not the smartest idea I've ever had. Ah well, none of that matters now anyway, hopefully I'll get a proper install done soon. :-) On that note, can an admin please enable my PM facility so I can make contact with an installer? Would be much appreciated. Thanks. [/QUOTE]
Insert quotes…
Verification
Post reply
Forums
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
Accept
Learn more…
