Crazyscan with Nova HD S2
statalite
SF8008
DiSEqC motor with 1m dish
Zone 1 @ 28.2°E
Zone 2 @ 28.2°E
SMR 1224
UK Midlands
I had a look at the other threads around the site so hope i'm not duplicating anything.
I have a Nova HD S2 and am trying to use crazyscan with it.
XP32
crazyscan 1.0.1.94
extracted reqlibs into the same folder.
using StreamReaderEx for BDA Tuners 1.1.0.1162 downloaded from here.
Upon startup it now says "RFScan not supported"
Is my card supported?
Is there anything I am doing wrong, do I need to put the crazycan folder in a specific place?
remlap
Wales
It is not compatible.
statalite
SF8008
Zone 1 @ 28.2°E
Zone 2 @ 28.2°E
SMR 1224
UK Midlands
Ah ok thank you, hiding to nothing then.
